daniboy1_2_3 0 Posted April 23, 2008 Im in the process of replacing my orignal oil cooler on my g60. I have come to putting the new one back on and wondered if anyone can tell me if there is supposed to be a seal between the filter housing that is bolted to the block and the cooler itself? I dont remember taking one off but it seems like there should be one as oil is flowing just inside of it?? any help appreciated. Quote Share this post Link to post Share on other sites
coolrado 0 Posted April 23, 2008 yeah there should be a green paper gasket between the oil filter/cooler mount and the block, they are only pennies from the stealer. Quote Share this post Link to post Share on other sites
davidwort 0 Posted April 23, 2008 I think he means housing to heat exchanger, not housing to block, that would be a rubber o-ring, part no. 038 117 070A Quote Share this post Link to post Share on other sites
daniboy1_2_3 0 Posted April 23, 2008 I know there is an o ring on the oil filter then there is one on the underside of the cooler, these two sit together. However on the top of the cooler i dont remember there being anything sitting between it and the oil fiter housing that bolts to the block? i have replaced the green paper gasget already. Thanks so far. Quote Share this post Link to post Share on other sites
davidwort 0 Posted April 23, 2008 like I said, the part number above is what you want between bracket and heat exchanger, it's about 6cm in diameter. Quote Share this post Link to post Share on other sites
