steveo29 0 Posted May 4, 2008 my g60 hasnt felt right in ages feels really wrong under 2800, it bogs /stumbles and feels really flat and wont wake up until 2800 all service parts, timing , cam timing is all good , and its been at pitstop for him to check it over for said fault and he said the map is fine any ideas? its not a fun car to drive at the moment im half thinking theres alot of timing being pulled out maybe? make any sense? Quote Share this post Link to post Share on other sites
flusted 0 Posted May 5, 2008 either lambda or temp sender Quote Share this post Link to post Share on other sites
boost monkey 0 Posted May 5, 2008 blue temp sender is a good starting point. Notorious for going on the Gs. Quote Share this post Link to post Share on other sites
steveo29 0 Posted May 5, 2008 yeah good point on the bts..is there a way to test it as its fairly recent and a genuine vag Quote Share this post Link to post Share on other sites
boost monkey 0 Posted May 5, 2008 I think you can check the resistance across the terminal? Lemme pull out my mk2 haynes... Sorry, doesn't seem to say how to test it. They're only about £10ish anyways (iirc) and are quickly swapped out. This will affect your economy too, so not a bad thing to swap out for new. Quote Share this post Link to post Share on other sites
flusted 0 Posted May 5, 2008 About £25 from vag. think you can measure resistance in ohms when cold and when hot, remember someone saying 2000ohms but unsure whether thats hot or cold Quote Share this post Link to post Share on other sites
steveo29 0 Posted May 6, 2008 right just been for a drive with the knock sensor unplugged ...seemed better and i could hear pinking around the revs where it bogs so im guessing the timing wants backing off some more , and the knock sensor is doing its job...or can they pull too much timing /be over sensitive? Quote Share this post Link to post Share on other sites
steveo29 0 Posted May 19, 2008 right played around with it some more and it felt like it was better with the o2 disconected so ive purcahsed a bosch universal sensor and it seems to have fixed it...seems to go a bit better too Quote Share this post Link to post Share on other sites
