ianmorgan50
kent cams G60
hi all
right project g60 is being started as soon as the P&P head in done so now its time to think about the cam i had a look at kent cams website and the only G60 they list is for the golf is the golf engine the same as the corrados?
thanks all
stick with the G-werks one if you check out most peoples build specs on here they have most gone for the G-werks one
its tried and trusted mate
cheers
stu ..
whys that i had a kent in my golf and it was relly good
Cos the shirck is really REALLY good :D
yeah i think as above, so 1 set of 4 valves stay open for longer than the other 4.( not sure wheather its inlet or exhaust though).
Give a smooth idle but power everywhere
I had a Newman cam which I was pleased with on my G - G Werks set it up for me with a Schrick map and it worked a treat. You could always get Newman to grind you a Scrick profiled cam. You pay a lot of money for the brand with Schrick - it's only a lump of machined metal after all
