mattkh
Not so funny request for a picture
Hi
I need a picture of the inside of 1.8 16v ignition lead plug end.
I cannot see what grabs the neck of the plug. If it is just a sit on top, then surely warm weather can cause misfires.
why do you think warm weather would cause a plug lead to make it misfire? gets pretty warm in there year round when the engine is running
dont have a pic but its much the same as any other lead...clips onto the top of the plug and the rubber part is a snug fit in the head
some just push in (ealry ones) later 1s have like a thread in the middle of the dizzy cap that the lead clips too if that makes sense
Hi
Thanks.
The dizzy end of the lead has a wire clip that I can see. This clip grabs the neck of the 'thread-in-the-middle-of-the-dizzy'.
But I cant see any such clip on the plug end of the lead. If you can confirm the plug end of the lead with a photo, that will be great.
What a total b@stard to photograph!!!!
How's this, doesn't really show much, not much room for an angle shot!
Plug end.JPG[/attachment:zv1osl4w]
Plug lead reseats with an audiable 'click!'
Hi
Thank you.
Is it the 6inch deep lead from a 16valver. If it is ,what brand are the leads.
Vw leads from a 1990 1.8 16v. Yeah the deep-down inside buggers! If you're going to replace them OEM is probably your best bet, they'll be around £80 a set but apparently better quality than non-original leads.
Mine's on its second set in 178,000 miles!
You pays ya money etc.........
