kaiserVR6 0 Posted June 5, 2008 Last night i started the job of fitting a polished intake manifold, only to find that after removing the assembly some 'tool' has managed to round the head on the allen bolt!!!!! :bad-words: so i bot it all back together and the car drives fine. Then this morning i set off to work and all is well with the world, when i stop at a set of lights and the revs stay at 3,000rpm, and when i pulled over to have a look the throttle cable is not tight but the throttle doesnt want to return to the correct position! I have checked everything i can think of and i am now stuck HELP!!!! :help: Note to self dont fix something that isnt broken! Quote Share this post Link to post Share on other sites
Toad 0 Posted June 5, 2008 Take the throttle cable off the throttle body and check it's operation to find out why it isn't closing properly, my valver had a habit of the throttle cable sticking partly recently, bt a bit of a fiddle, and a squirt of wd40 sorted it out. Quote Share this post Link to post Share on other sites
kaiserVR6 0 Posted June 5, 2008 thats the probelm though, there is no tention on the throttle cable, it the actual sprung part which doesn't want to return to its normal position?! Is the throttle body on its way out!? Quote Share this post Link to post Share on other sites
boost monkey 0 Posted June 5, 2008 Wouldn't have thought so, but give it some grease/lube like Toad suggested and report back. Quote Share this post Link to post Share on other sites
kaiserVR6 0 Posted June 5, 2008 will do, going out in my lunch to see what i can sort out..... underneath the throttle body there is, what i can only describe as, a sensor type unit that compresses, this doesn't have any elec connections to it though. it seems to be some kind of stop, but i am not sure........i think i may have adjusted it slighty.....could that be the cuase, if anyone has any idea what the unit is that would be great!? Quote Share this post Link to post Share on other sites
andy 0 Posted June 5, 2008 That part is a damper, to stop the airflow from being cut off dead, just closes the throttle plate a little bit more gently when its nearly shut. If you have adjusted it wildly then yes you could probably hold the throttle part open with it. Quote Share this post Link to post Share on other sites
kaiserVR6 0 Posted June 5, 2008 yeah it was the damper, now i can see it in the cold light of day it was a bit easier to spot! the bracket needs straightening and i need to sort it out. Just rying to figure out how to get the last bolt that some numpty as round the hex head on the throttle body, do i cut a slot in it with a hack saw, or drill the head off and slide the throttle body over the shank and then i can remove the bolt frm the inlet manifold at a later time, while i have the polished one on!? opinions?? Quote Share this post Link to post Share on other sites
DanVW 0 Posted June 5, 2008 Irwins to the rescue!! :clap: http://www.amazon.com/IRWIN-394001-Bolt ... B0000CCXVZ They are the dogs do da's and have saved me from allen bolt nightmare's too many times to count! Quote Share this post Link to post Share on other sites
junkie 0 Posted June 5, 2008 I can confirm the Irwins are a must bought a set last week and they pulled the bolt out instantly after trying for 2 hours, bought after somebody on here recommended me to them. Quote Share this post Link to post Share on other sites
kaiserVR6 0 Posted June 6, 2008 are Irwins going to actually work on an allen bolt, there is only half the head exposed, the rest is spot faced into the throttle body!? Quote Share this post Link to post Share on other sites
DanVW 0 Posted June 6, 2008 I dont know but I promise even if they dont work on this bolt, you WILL be very glad you have them the next time you run into this problem! I would suggest you go get a set and try them, so much easier than cutting off the head of the bolt and trying to extract the thread!! :? Quote Share this post Link to post Share on other sites
boost monkey 0 Posted June 6, 2008 Irwins should grip for sure. If you get really stuck and the car is driveable, go give a garage £5 to weld a nut onto the top of the allen bolt and then unto it as per normal. That should work fine. :salute: Quote Share this post Link to post Share on other sites
tandino 0 Posted June 6, 2008 Alternatively try a torx bit, Hex bits grip on the flats whereas torx will grip on the points. Quote Share this post Link to post Share on other sites
pete_griff 0 Posted June 7, 2008 if you do try with torx, all well and good, but make sure you have some high quality torx bits otherwise you will sheer the torx bits if they are cheap. also irwins are amazing - the two allen head bolts that hold on the rear caliper carriers were absolutely rusted and fubar'd on my car, nothing was getting them out. i "woke them up!" with the tap of a hammer and then they came straight out with irwins - top notch bits of kit - i have a collection of them :D Quote Share this post Link to post Share on other sites
