H8RRA 0 Posted July 4, 2008 just chaned all timing gear, flywheel, clutch etc and out all back together but have a problem with the geaer linkage. The linkage and counterweight are very loose and the gear selection very sloppy. It seem correctly put together but its far from good in operation. looked at pic in the wiki but can't see anything incorrectly assembedl. anyone had suc problems or suggestion toe resolve slopy linkage/loose counterweight ? Quote Share this post Link to post Share on other sites
davidwort 0 Posted July 4, 2008 I take it you didn't remove the shift tower from the box and just unclipped/unbolted the shift and selector cables, did you remember the thick round washer under the cable end on the counterweight/shift cable fixing bolt? Quote Share this post Link to post Share on other sites
H8RRA 0 Posted July 4, 2008 i did remove everything as the plastic broke - but i have all the parts - anyone got a decent shot of the assembly of all the parts together to check its correct? Quote Share this post Link to post Share on other sites
Toad 0 Posted July 4, 2008 I've got one on my phone, but no cable. I'll pm you my number so I can send it to you if you want. Basically it's linkage, washer, cable end, bolt, shift wieght, nut, from the bottom up. The washer has to be the right size, ie. doesn't go over the stepped section of the bolt. Quote Share this post Link to post Share on other sites
