was8v
Grr VAGCAT wrong numbers. PN for gear linkage bolt req (pic)
Why did they bother with VAGCAT, lots of part numbers are out of order and dont correspond to the part indicated.
Anyway, I'm after the part number for the little captive bolt that sits in the gear linkage, under the shift weight and cable.
Its numbered 50 in the diagram, vagcat calls it a "gasket" with part number: N 90429401
Thats clearly wrong, its mroe likely to be 51 which is described as "nut, square M8" with part number 1J0711256
Can anyone confirm this who has the proper etka? Cheers.
the part number and diagram number are above the description of each item, so
50 N 90429401
nut, square
M8 /
Looks correct to me.
or pick up an M8 square nut from B&Q.
My good man, let me demonstrate to you how the odd-listing world of VAGCAT works :salute:
Coolrado is completely correct, the part number is above the description, have a look a these screenshots I just mocked up:
This is how you were reading it, you are correct in presuming that the dark grey lines indicate each item's 'box', but they do not. You need to look at the 'box shading' as follows:
This is correct.
Hope this helps,
Jon.
Duh, I feel stupid now! I've been using VAGCAT for ages for the diagrams but never trusted the part numbers!
Thanks very much!
Maybe your little guide could be stickied or put in the knowledge base?
Theres a random M8 nut on there at the moment, and it isnt held still by the "cage" of the selector. This makes it almost impossible to tighten properly. Hence I'll get the correct part, EDIT: 0.26 euro is ok for a nut!
