loopylindsay 0 Posted July 30, 2008 hello its only started happening reacently but it sometimes finds it hard to go into first and second? its as if it feels like im pushing the gear stick over too far and it gets stuck :shrug: if i put it in neutral giggle it a bit and softly move it it goes in. any ideas? thought it may of been the slave cilinder or a bolt loose on the selecter but i dont know. help will be much appreciated Quote Share this post Link to post Share on other sites
Jim 2 Posted July 30, 2008 Have you checked for the infamous selector 'circlip' being present? Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted July 30, 2008 If loopylindsay says its missing and ive sorted it, Jim you've just won the shortest thread award! :D Bravo! Quote Share this post Link to post Share on other sites
loopylindsay 0 Posted July 30, 2008 i will have a look! if it is missing im guessing i just need a new one? anyone got a pic of where it may be? Quote Share this post Link to post Share on other sites
Walesy 0 Posted July 30, 2008 Try using the search! :tongue: Quote Share this post Link to post Share on other sites
loopylindsay 0 Posted July 30, 2008 ok will do. wat can a girl do eh! so im lazy had a busy day Quote Share this post Link to post Share on other sites
Jim 2 Posted July 30, 2008 If loopylindsay says its missing and ive sorted it, Jim you've just won the shortest thread award! :D Bravo! Certain problems come up so frequently and 90% of the time they are just what they sound like - so I find it easier to give the easiest response first, then let the actual technical people dissect the problem later on if that doesn't look to be the problem ;) Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted July 30, 2008 If loopylindsay says its missing and ive sorted it, Jim you've just won the shortest thread award! :D Bravo! Certain problems come up so frequently and 90% of the time they are just what they sound like - so I find it easier to give the easiest response first, then let the actual technical people dissect the problem later on if that doesn't look to be the problem ;) Yeah i agree. I can only help on the common problems. Leave the rest to those with more knowledge. Quote Share this post Link to post Share on other sites
Toad 0 Posted July 30, 2008 Do you struggle when it's hot? How's reverse? Quote Share this post Link to post Share on other sites
k551 0 Posted July 31, 2008 I had the same problem last week. On top of the gearbox where the cables connect from the gear level, there is a small plate with a bolt through it. This can be used to adjust the selector. My bolt came loose and the plate was able to move about on it's own. Get the bolt in the middle of the plate and tighten. If you have trouble finding it I can take a pic. Quote Share this post Link to post Share on other sites
The_Dude 0 Posted July 31, 2008 Could be a number of things really, but take a look at this thread about adjusting the linkage - i don't think you have the specific problem I had but there's loads of pics and info in it about other stuff, it may help. http://www.the-corrado.net/.archive/forum/viewtopic.php?f=23&t=70164 If it doesn't then you can rule it out! Quote Share this post Link to post Share on other sites
loopylindsay 0 Posted August 3, 2008 cool thanks guys.i have always had a bit of trouble with reverse as in it crunches!(yes i have my foot all the way on the clutch) but if i do it slowly its ok. ill have a look at all those things and hopefully be able to sort it.fingers crossed Quote Share this post Link to post Share on other sites
loopylindsay 0 Posted August 10, 2008 wahoo corrado forum are geniuses once again thanks guys it was the circlip and its now fixed and is loads better changing gears. the thing had shattered. Quote Share this post Link to post Share on other sites
Jim 2 Posted August 10, 2008 Yay. I earn 10 smug points :D Quote Share this post Link to post Share on other sites
alphabat 0 Posted October 13, 2009 I'm new to the site and forums all together. i just bought a 1992 Corrado SLC for my son and all of a sudden we could not get 1st or 2nd either. reading this information and joining the site was a godsend of information. I'm a mechanic by heart and trade (aviation) but was not in touch with VW corrado's. its like you said, 2 minute adjustment at the gearbox and all is good. thanks much to all of you for posting your stuff. :clap: Quote Share this post Link to post Share on other sites
