Jenna
intermittent running problem 16v
starts and runs ok untill operating temperature then cuts out totally. 20 mins once cooled starts again no problem
any ideas please ? :)
Hi
Can you elaborate on the cuuting out.
Does it cough,splutter. Do the ignition lights come on. What does the rev counter show.
And what spec is the car.
the rado is a 1990 1.8 16v
it starts and idles no problem,and revs up but as soon as put into gear to pull away ,it kangaroo hops all the time it wont drive smooth.
the cutting out problem is sorted ,it was a tear in the air intake pipe,that has been replaced,also have checked rotar arm and dizzy cap,i have changed the ht leads also but the kangaroo hopping is just as bad
problem sorted,new lift pump(intank) and the red wire on the 3 pin plug at the bottom of the dizzy was about to snap,a little solder and runs like a sweetie :D :D :D
