steveo29 0 Posted August 31, 2008 i guess this can apply to all models but i have a g60 have you repaired your o2 harness ? where was it damaged and how did you go about making it right? i suspect i might have issues , but understand the signal wire is sheilded, so how do i replace that?? Quote Share this post Link to post Share on other sites
coolrado 0 Posted August 31, 2008 Mine was broken off at the connector, so i just popped the pins out of the connector soldered the wires back on to the pins, clipped them back in and re sealed the connector with some pu sealant. if you want to repair shielded wire just make sure you cut the centre core a bit shorter, solder it together then heat shrink or tape over it, (adhesive lined heat shrink is better as its water tight) then as the shielding should be longer you should be able to pull it over the top of the heat shrink or tape and solder it together in a few places, making sure there are no gaps around the circumference then heatshrink or tape over that as well. Quote Share this post Link to post Share on other sites
steveo29 0 Posted August 31, 2008 i was really hoping to replace the whole length pin to pin , maybe route the signal wire away from the others in some pvc sleeve? Quote Share this post Link to post Share on other sites
