Jim Bowen 1 Posted September 18, 2008 Am thinking of lowering the back 60mm but not sure if that will be enough or not? i seem to remember some 60mm springs looking very similar to 40mm also if i get what they call a 60/40mm kit is that 60mm rears and 40mm fronts? Quote Share this post Link to post Share on other sites
smiffy-g60 0 Posted September 22, 2008 your far better off buying coileys mate, you'll be able to lower the car to the hight you want. Quote Share this post Link to post Share on other sites
n3p 3 Posted September 22, 2008 Refer to my pics from the 'Borbet Wheels' thread mate, shows mine lowered 60mm all round 8) Quote Share this post Link to post Share on other sites
boost monkey 0 Posted September 22, 2008 Am thinking of lowering the back 60mm but not sure if that will be enough or not? i seem to remember some 60mm springs looking very similar to 40mm also if i get what they call a 60/40mm kit is that 60mm rears and 40mm fronts? different length springs can be rated as a different amount of 'drop' because of a difference in spring stiffness or pounds per inch rating, so they may have the same free length off the car but when you put them on and lower the car back down on it's wheels they will 'settle' or compress different amounts. obviously softer springs will lead to a more wallowy ride :salute: personally, I wouldn't recommend a drop of more than 40mm as the suspension geometry (if left unaltered) is compromised. If you want to fill arches, maybe some bigger wheels? :shrug: Quote Share this post Link to post Share on other sites
A1 VR6 0 Posted September 22, 2008 Mine's 60mm rear and 45mm front on coilies and it does rub the inner wheel arch occasionally on the front. Some people have removed this but doesn't do much for rust protection. Got 17's on but it also rubbed with 16's :) Quote Share this post Link to post Share on other sites
Phil K 0 Posted September 23, 2008 This is how my old one looked lowered 60mm front and rear... HTH Quote Share this post Link to post Share on other sites
smiffy-g60 0 Posted September 27, 2008 Not sure how much its lowerd but its more than 60, ide say the rear is around 80 and the front a touch more. Inner arches have been taken out of the front. Quote Share this post Link to post Share on other sites
Goldie 2 Posted September 27, 2008 I think mine is lowered about 65mm on the back and around 60 on the front and its spot on for the wheel size.. Quote Share this post Link to post Share on other sites
cdem 0 Posted September 28, 2008 Not to sure how much ive dropped mine but the sump is approx 3-4cm from the floor Quote Share this post Link to post Share on other sites
nathan.g4 0 Posted September 28, 2008 low and slow baby :) Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted September 28, 2008 Sweet rado Cdem :D But id love a set of porsche reps like PhilK's. Phil did you have any rubbing issues with that drop on those wheels? Quote Share this post Link to post Share on other sites
cdem 0 Posted September 28, 2008 Id love some Porsche wheels on mine, think they look so smart on Corrados! I havnt had any rubbing issues but ive had problems with my sump being so low, speed bumps are just a no no Quote Share this post Link to post Share on other sites
Stuckinthe90s 0 Posted September 28, 2008 Not to sure how much ive dropped mine but the sump is approx 3-4cm from the floor Really like your 'rado, nice and simple, good work. Hope to see a new photo shoot :salute: Quote Share this post Link to post Share on other sites
cdem 0 Posted September 28, 2008 Thanks alot :D went out to take some pictures the other day with my mate so ill upload them when i can Quote Share this post Link to post Share on other sites
