a98pmalcolm 0 Posted September 28, 2008 hay guys. just a quick question if any 1 knows the answer or has simler experiances. every few months i like to hose down the engine bay of my G60, makes it nice and clean and keeps in in the condition that i spent ££££ on making it look like its come out the show room! But when i drive off and give it a test drive it starts to spluter when the throtle opens up, but when i put my foot rite down when the throtle is on full it sounds like the engine turns completly off so take my foot off the accelarator and it sonds like its running again! Bit wierd but ualy it all drys up by the next day and all is well. Just wonderng if any1 knows y so im a bit more clued up on what is happening Thanks Paul Quote Share this post Link to post Share on other sites
VR6 0 Posted September 28, 2008 You're spraying water all over your engine electrics and wondering why it's not quite performing after that? Either keep the water away or start bagging up the important parts if you insist on doing it. All IMHO - no experience but sorta based on common sense. Quote Share this post Link to post Share on other sites
coolrado 0 Posted September 29, 2008 my guess would be water in the closed throttle switch, give it a squirt of WD40 and it should be fine, I take mine down to the tesco jet wash and do my engine bay every couple of months and had the same problem, it's fine once it's dried out or had a squirt of WD40. Quote Share this post Link to post Share on other sites
boost monkey 0 Posted September 29, 2008 sounds like you've fooked the ignition system :nuts: may i recommend a pushbike as your vehicle of choice from now on? Quote Share this post Link to post Share on other sites
a98pmalcolm 0 Posted September 29, 2008 well coolrado has the idea as many people do! so when we turn up to shows our engine bays are spotless! noting is fooked ether it always drys up and runs perfect! just wanted a bit more inside knolage on the G60's. more i know the better! These are the results of a good clean up! except i got a BBM charger now!... Quote Share this post Link to post Share on other sites
waynos 0 Posted September 29, 2008 shizzle that is a very clean bay! that a dump valve i can see? how does that sound? Quote Share this post Link to post Share on other sites
Valerian 0 Posted September 29, 2008 Water will seep down into the spark plug holes and cause the spark plugs/leads to short circuit. Best thing to do after an engine wash is to take each spark plug out and let the water drain into the cylinders. Then replace the plugs and start the engine to evaporate the water from the cylinders. Quote Share this post Link to post Share on other sites
Toad 0 Posted September 29, 2008 Or leave it out in the sun to dry out, before spraying WD40 onto the ignition system. I'd try to keep the alternator, starter motor, dizzy and any sensors dry though. Quote Share this post Link to post Share on other sites
Alexander 0 Posted September 29, 2008 I'd love to clean my engine bay like that but I'm far too scared I'd fubar it! I stick to a damp cloth and some elbow grease.. Quote Share this post Link to post Share on other sites
a98pmalcolm 0 Posted September 29, 2008 haha cheers waynos, yer what u need to do is blank off the boost return coming from the inlet manifold then the dump valve u fit will be LOUD! BUT u will need one with a very soft spring so it can release boost during idle! this is a Baily DV34 and its incrediabley loud and sounds awsome bro! u gotta do it u will love it! ok thanks for the tips Valerian and Toad :) its nice to get tips and help from VW owners! Thanks Guys! Quote Share this post Link to post Share on other sites
a98pmalcolm 0 Posted September 29, 2008 Oh there is a well good way of doin it if u dant wanna hose it down, i do it after hosing it down anyway. use disk brake cleaner! spray it in the cloth, and gently wipe down, takes oil and grime clean off and u only need to use 1/4 of the amount of elbow grease...lol ;) Quote Share this post Link to post Share on other sites
waynos 0 Posted September 30, 2008 did you have to modify you dump valve with a softer spring then? Quote Share this post Link to post Share on other sites
a98pmalcolm 0 Posted September 30, 2008 no mate im pretty sure the DV34 valve comes like that! its not adjuastable! a motorsport company had to take my monza one off coz it couldnt work properly coz the spring was to hard! the DV36 looks the same but is designed for those big 400+BHP cars so the spring with will be alot harder so make sure its the DV34, im getting my valve reported and polished so when i got it running nicer i will get a vid for u bro! and let u know! Quote Share this post Link to post Share on other sites
SamG40 0 Posted October 1, 2008 Dump valves are a waste of time on G chargers imo. Boost return valve does a much better job as its what it was designed for. Quote Share this post Link to post Share on other sites
a98pmalcolm 0 Posted October 1, 2008 yer the dump valve isnt really needed! its really more for show, and i know it sound silly. but there will be a small amount of boost lost through that valve that opens and closes on teh inlet manifold so it can help a little, and with out the boost return it mean no oil mist in the charger and most importantly NO HOT AIR! BBM say but removing the boost return pipe, blank off the charger and run the ISV reroute kit, thats a 10BHP increase! Quote Share this post Link to post Share on other sites
