blue95
1995 2.0 16v Fuel pump wiring?
Bit stuck trying to find the wire that goes to the ECU that makes the fuel pumps kick in.
Was told it was red/yellow, and to test it by earthing on the car body (fuel pumps should prime). However before earthing to check there is no 12v supply coming from the wire....prob is I have 12v coming from the red/yellow wire??? :scratch:
Any guidance most appreciated... :notworthy:
Hi
What are you trying to eliminate by finding this wire ?
Just trying to find the wire that will make the fuel pump run
Hi
I take it you are trying to find if the pump has given up the ghost.
Pick up the carpet in the boot on the drivers side, and put up a picture of the end towards the seat. It should show a round plate with three screws.
Nope...I have done an engine swap and an fitting an aftermarket ecu, need to find the wire for the fuel pump relay so it can be connected to the new ecu. Was told it was the red/yellow wire and there should not be 12v coming from it. not the case though?
do not earth the red/yellow thats the live to the pump. If you have live to it on cranking then that wire and the relay is fine.
red/yellow = pump live
Brown pump = earth
purple/black = sender feed
thin brown = sender earth
Think thats right
Brown pump = earth
Think thats right
Hi
These are the wires at the 4-pin connector at the top of the fuel tank in the boot.
