voo51 0 Posted October 6, 2008 I have coolant leaking, well pouring out, but only when i turn my engine off. If the engine is on for a few minutes only a little comes out but if i go for a drive as soon as i turn it off alot of water comes out. I have tryed to see where it is coming from but i cant see. It looks like it is dripping from the n/s of underneath the car inline with the passenger door. The car runs perfectly fine otherwise apart from my heaters have stopped working also. I thought my heater matrix but my footwells are not wet at all and the water only leaks when the car has just been turned off. Has anyone any suggestions? :help: Quote Share this post Link to post Share on other sites
dirtytorque 0 Posted October 6, 2008 leak is more pronounced when the engine is cold because heat makes objects expand and the opposite happens when cold. In terms of finding the leak,its just a case of having a good look. Sorry not more help.Just concentrate around the areas where water pipes join etc. Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted October 6, 2008 doesn't the secondary water pump come on when you switch engine off? Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted October 6, 2008 if you look at engine from the bay on a RHD drive car, its on the top left hand corner of the engine, if its a VR that is Quote Share this post Link to post Share on other sites
dirtytorque 0 Posted October 6, 2008 valver if it's the car in sig. Quote Share this post Link to post Share on other sites
voo51 0 Posted October 6, 2008 It is a 16v. It appears wet around the base of the coolant bottle and below surrounding area but when water is dripping under the car there is no apparent place in the engine bay it is coming from. I had the same thing happen on a VR6 years ago but cant for the life of me remeber what it was in the end!! Quote Share this post Link to post Share on other sites
AlgarveVR6 0 Posted October 6, 2008 Change the expansion tank cap and check the matrix.............nother thread running today with similar issue Quote Share this post Link to post Share on other sites
voo51 0 Posted October 7, 2008 I have taken the black plastic cover off the side of the coolant bottle and the coolant is coming out of that overflow/breather hole. So, i have ordered a new cap and hopefully it'll be sorted! Thanks for the advice. Quote Share this post Link to post Share on other sites
Reggit 0 Posted October 7, 2008 If your heater's not working you've probably got an airlock in the cooling system, or possibly jammed (shut) thermostat meaning the coolant won't flow properly and you'll probably overpressurise the system resulting in coolant escaping from wherever it can. Quote Share this post Link to post Share on other sites
voo51 0 Posted October 7, 2008 I have now fixed the heaters! I took the dash apart again and it turns out i hadn't clipped the blue heater wire to the unit, causing the cable to move but not inside the sleeve like it should. :) My new cap arrives toorrow so once that is on i will see if it solves my overflow problem. Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted October 7, 2008 lovely jubbly!!! :D Quote Share this post Link to post Share on other sites
dr_mat 0 Posted October 7, 2008 Also check the hose on the back of the cylinder head, underneath the HT lead cable tidy. And if that's gone, check your engine mounts .... Quote Share this post Link to post Share on other sites
voo51 0 Posted October 13, 2008 New water cap fitted and no more leaking! Also had full service and compression checks just to make sure and she runs better than ever. Thankyou so much guys :) Quote Share this post Link to post Share on other sites
