will.s
VR6 cylinder inspection
i need to remove the head on a VR6 to inspect a cylinder becouse its only firing on 5 cylinders.
does anyone have any advise on this for me or does anyone strongly advise against it??
i have tried:
new plugs
new ht leads
new MAF
new lambda
new ISV
what else may be the problem??
also the plug nearest to the air box (i think its number 6) has oil on it! :(
will
have you done a compression test on it? That will identify if any of the cylinders are losing pressure!
take out the plugs and inspect them first,this will tell you allot....wet,black,white,carbon deposits etc.
If nothing is found inspecting the plugs,then you should carry out a compresson test.
If compression readings are low,then carry out a wet commpresion test by adding in about 5 squirts of oil in the plug holes and then carring out the compression test.
if nothing is found on the compression test it would sugest an electrical fault.
Im sure someone will come along and tell you to plug it in to vag com at some point in this thread.....
If there is oil on the top of the plug, then it's probably some heavy handed oil filling or the rocker cover gasket. Remove the plug and clean it.
Could be a dodgy injector too. Is it definitely No.6 that is missing?
