Chris Smith 0 Posted October 22, 2008 :wave: Hi My new Corrado is giving off a perculiar hot oil smell when she warms up and can be smelled while in the driver's seat even with the windows closed. I popped the hood when I got home and could not find any immediate evidence of a leak :scratch: Are there any common problems which might be causing this? Quote Share this post Link to post Share on other sites
Toad 0 Posted October 22, 2008 PCV valve split and dropping a small volume of oil onto the exhaust manifold? Quote Share this post Link to post Share on other sites
Chris Smith 0 Posted October 23, 2008 Thanks for the tip Toad. I'm not sure where to find the PCV, but I think I got it in these photos. I does appear to be a bit oily around this area, I'll do a bit more investigating. It only tends to start smelling after about 30 mins on the road or if i've been giving it a bit of stick. Quote Share this post Link to post Share on other sites
dr_mat 0 Posted October 24, 2008 That's the PCV valve. Typically it has fallen apart after many years of heating and cooling cycles and is breathing crank case vapours straight to the atmosphere. Quote Share this post Link to post Share on other sites
wazza 0 Posted October 24, 2008 Sounds like what mine was doing - and yes that PCV valve had split, glued it up and much better now. I still get a vague oil smell sometimes so I might have more leaks elsewhere... Quote Share this post Link to post Share on other sites
Chris Smith 0 Posted October 27, 2008 Ok, thanks guys. As per thisthread I'm going to look at changing the PCV. Tonedef very kindly dug out his paper work for me and gave me some part numbers for this valve from ford.. F7364573 N/STK 002881/VALVE A It was 24.98 inc VAT Quote Share this post Link to post Share on other sites
Chris Smith 0 Posted December 12, 2008 I was driving my Corrado today and I got a very pungent smell of burning oil. I was then met with smoke billowing out from beneath the bonnet. The oil leak seems to have grown. The smoke was coming from the point circled in red in the picture below. Any ideas as to why this might be happening? Quote Share this post Link to post Share on other sites
andy 0 Posted December 12, 2008 The big bolt head in the centre of the circle is the timing chain tensioner bolt and unlikely (unless loose) to be related to your problem. I'd guess maybe your cam cover gasket is leaking? Quote Share this post Link to post Share on other sites
Roger Blassberg 0 Posted December 12, 2008 ...or maybe the timing cover joint where the head gasket goes between the 2 parts is not oil tight. Best wishes RB Quote Share this post Link to post Share on other sites
Toad 0 Posted December 12, 2008 The bolts that go vertically between the two halves often fall out which might not help. Quote Share this post Link to post Share on other sites
