Cnut
Replace thermostat without removing the housing?
I just spent most of the morning replacing the thermostat housing on my VR with a spare new one I had because the old one was leaking badly. Got it all installed and refilled the coolant and let it idle for a good 15 minutes. The water temp settled at around 100C which I thought seemed quite normal, I then took it out for spin and noticed that the water temp dropped to about 75C and only rose when the car was at a standstill.
To me this sounds like a dodgy thermostat, I really don't/can't be assed to remove the whole housing again just to replace the thermostat so I was wondering whether it is possible to change with the housing still in place?
Cheers
Phil
No it wasn't I assumed it would be alright because the stat is only about a year old and its a VW one but when it was on my old VR it had the same symptons so I'm guessing it must have been duff all along...
Always worth testing a new stat in a pan of boiling water- not much good to you now. I'd bite the bullet, get a new one and replace it. Now you know what you're doing with the housing etc, it should be quicker/easier than before. At least you'll have peace of mind.
