tombell999
relocating on valver?? any ideas?
Guys i wana try to relocate the fuel injector rails on my valver....has anyone got any possible ideas where i could put them? i would like to move them so there slightly more hidden because they look a bit ugly, and so i could change my air box as the standard one is 'boring!' even though i have a power rohr on it aswell....anyway thanks guys lets see how this goes! :?
you could fit braided (mk2 style) hoses rather than the rigid metal lines, but be careful where you route them, they're mounted away from the engine a bit and in the flow from the radiator fan to prevent fuel vapourising in them when the car is still or switched off on hot days, there is a temp switch for the fan mounted near them on the cam cover for this reason.
I'm not sure but the braided mk2 lines may now be obsolete from VW, in any case it's probably cheaper to get them made up by a fuel/hydraulics line specialist, not used any myself, trawl the yellow pages or seach some of the other car forums I guess.
ok well I'll have a look anyway! One more thing..... If I relocated the rails and put an air intake leAding to them could that possibly work?
