jonnyoutram 0 Posted November 26, 2008 hi, i have spent a while on the knowledge base but could not find anything. i have a 1995 m reg vr6 storm, when you start the engine from cold the car seems to run fine but as soon as u give the car any throttel, once the revs drop it seems to struggle! it seems like suddenly 2 cylinders are not fireing?? some times it almost stalls, its sounds really roulgh and then eventuall it sorts itself out once the car warms up?? whats going on? i have had a new: coil pack ht leads plugs oil filters i have cleaned out the throttel body and induction pipework checked for air leaks and changed a few rubber vacume hoses. i thought it could be the isv so i took it off cleaned it, lubed it up and then tested it and it seemed to work fine... i stuck it on vag com and all that showed up was a few funny readings from the lambda probe, my specialist mechanic mate said it should not cause a problem tho. any ideas ppl?? :notworthy: :notworthy: :notworthy: Quote Share this post Link to post Share on other sites
iceviolet 0 Posted November 26, 2008 I had a bad missfiring problem last week, and before this my car also behaved like yours does, struggling a bit after you give it some. It turned out to be the coil pack on mine. But as you have had a new one, its very unlikely that it is that. The lambda reading should hover around 1.00. I had a few suggestions by other memebers to the cause of it though, The MAF sensor, knackered cat, blue temp sensor??? Quote Share this post Link to post Share on other sites
jonnyoutram 0 Posted November 28, 2008 I had a bad missfiring problem last week, and before this my car also behaved like yours does, struggling a bit after you give it some. It turned out to be the coil pack on mine. But as you have had a new one, its very unlikely that it is that. The lambda reading should hover around 1.00. I had a few suggestions by other memebers to the cause of it though, The MAF sensor, knackered cat, blue temp sensor??? is there any way of testing a coil pack? i know about the spraying water thing and looking out for arking but have already checked that and its not split...??? Quote Share this post Link to post Share on other sites
dr_mat 0 Posted November 28, 2008 You can buy spark testers. Quote Share this post Link to post Share on other sites
iceviolet 0 Posted November 28, 2008 I tried the water thing with mine too, didnt arc and the resin looked fine, no splits or cracks. I think on mine, one of the actual coils inside the unit had gave up the ghost. How recently has it been replaced?? Quote Share this post Link to post Share on other sites
jonnyoutram 0 Posted November 29, 2008 it was replaces about 6 months ago, its weird how it only does it for a bit on start up when cold only once revved!! is it possible that warming it up could make something electrical work better? Quote Share this post Link to post Share on other sites
dukest 0 Posted November 29, 2008 viewtopic.php?f=1&t=74001 no definitive answers here but just to show you its obviously not that uncommon.. Quote Share this post Link to post Share on other sites
jonnyoutram 0 Posted December 3, 2008 its really strange tho, are u all saying that the coil pac could have it running fine one minute then once revved up only when cold it could loose 2 cylinders till warmed up?? wouldn't it be difficult to test with a spark tester if its an intermittent fault? Quote Share this post Link to post Share on other sites
was8v 0 Posted December 3, 2008 When its missfiring, kill the enigne and pull the plugs that are missing immediatly. I've had a VR that oiled up its 1&6 plugs after a few k miles (I think due to bore wear) causing missfiring. You would see oil on the plugs and nasty deposits in this case. My current VR had a dodgy injector which failed spraying too much fuel which meant the plug didnt fire. You would have a plug covered in fuel and smelling of petrol if this is ths case. Quote Share this post Link to post Share on other sites
jonnyoutram 0 Posted December 4, 2008 amazing advice i will check! thank u so much!!! :notworthy: Quote Share this post Link to post Share on other sites
