krnau
16v KR X-Files
Does anyone with KR feel the following:
when I accelerate pushing the accelerator pedal slowly, it accelerates faster than if I push it all of a sudden.
:scratch: :scratch: :scratch:
yes, if you start off low revs opening the throttle straight away open the throttle body fully then it will cause it to bog as it is overfuelling. its not a problem jus the engine doesn't like that much fuel being chucked into the engine at low revs, its often known as heavy foot syndrome
edit: thinking about it, if its excessively bad could be the mixture being wrong on the co screw, which can be adjusted but i'd maybe do some research before fiddling
:norty:
thank you all for your replies.
