coullstar 0 Posted December 13, 2008 Ive got some Koni TA's & H&R springs for my VR and might be fitting them tomorrow. What Im wondering is what is the best setting for a fast road driving on reasonably bumpy roads? Also the rear plate circlip is on the middle groove, should I move this? Quote Share this post Link to post Share on other sites
Toad 0 Posted December 13, 2008 I've not fitted mine yet, so I haven't a clue on settings. But you can move the circlip depending on how high you want the rear of the car. Quote Share this post Link to post Share on other sites
coullstar 0 Posted December 13, 2008 Yeah I know, just wondered if someone had fitted the same combo and had to change the rear. Quote Share this post Link to post Share on other sites
Toad 0 Posted December 13, 2008 Ooops! Sorry. Quote Share this post Link to post Share on other sites
coullstar 0 Posted December 19, 2008 Anyone know know about the rear spring plate position as I should be doing them tomorrow? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted December 19, 2008 5 circlip slots on the rear dampers from memory, you want the 3rd one up from bottom with the H&R (green I assume) springs. Perhaps make the offside 4th up from bottom to level off the natural tilt to the right due to the engine block weight. That's what I did anyway and it worked well. Damper settings I found best for all conditions:- Front, 1.5 turns from soft Rear 0.5 turns from soft Try that and see how you get on Quote Share this post Link to post Share on other sites
coullstar 0 Posted December 20, 2008 Thanks, Ill give that a go. Quote Share this post Link to post Share on other sites
