RichG60
Making G60 exhaust quieter
Guys my G60 has the following mods :-
68mm pulley
rsr outlet
blanking plate
sns 5.5 chip
Gwerks Stage 4 charger
Miltek exhaust with no cat
Now the exhaust does sound nice, at idle its a bit loud though, when I first start her up she is crazy loud then it settles down. When your cruising around its fine but a bit boomy. Also sounds a bit tinney from underneath but put that down to not having a cat.
Now im not sure if my exhaust has blown baffles but are Miltek exhausts generally regarded as a louder exhaust on the G60 compared to other aftermarket brands?
I'm tempted to fit a standard exhaust but not sure if it would cause issues with the state of tune. Also would be a gap between the manifold down pipe and the exhaust due to the missing cat. :?
Rich
I think it's just the way the Millteks are tbh altho there is a lot to do with the fitment of these... try some new rubbers from VW maybe...
i spoke to pipewerks about this...tits pretty difficult to do as a g60 kinda flows twice as much air, you can go quiet but that is restrictive and the amount of heat the g60 puts out you will end up melting exhaust boxes...and that isnt good...ive gone through 4 exhausts where exhaust places told me it will be sufficient. i would go to pipewerks but they are faaaaaaaaarrrr!!
i was reading the user piano-something off this site has used a techtonics exhaust that utilises borla silencers which is quiet on his vr6t which may be possibility i havent heard of anyone using one on a G60...however i will be visiting charlie at prospeed(chek the site, alot of the high power guys around here swear by him) ...i would love for mine to be quiet but i think i may just have to suffice for a loud exhaust...or use a valve...hmm just thought of that while typing....research time!
from chopping and changing exhausts I've come to the conclusion that a) stainless is harder and always transmits more noise and b) the 'suitcase' mid/rear silencer where the exhaust crosses over from the centre to the backbox is carefully designed by VW to keep the system quiet, the vast majority of aftermarket exhausts just seem to incorporate a basic small silencer in this position, if at all, and that's not really enough. Because this silencer position is under the rear seats you often get a lot of booming, a couple of layers of dynamat or something will help a lot here.
I used to have a supersprint, however the bore isnt big enough...but yeh it sounded very nice!!...that was when the engine was standard mind...
Demon Tweaks sell exhaust decibel inserts, for this sort of application, I think they're only about 30 quid or so. Might be worth a look.
I think that turboed cars should be quieter than supercharged cars, as the turbo does a lot of silencing of the exhuast noise. It certainly seems to be the supercharged VR6s that are the loudest on the rolling road days anyway.
maybe the addition of another resonator or free flow catalytic convertor will reduce some noise.
I have a custom made exhaust I fabricated after my Eurosport reace headers with two pretty big Magnaflow resonators out to a supersprint rear muffler. I will need to add a catalytic just so the police do not harass me .
47b7d708b3127ccec26f48835d3000000016100QcOWzNuxcMQe3nww
47b7d708b3127ccec26fb7d39cb700000015130QcOWzNuxcMQe3nww
47b7d708b3127ccec26f37a39c8700000016100QcOWzNuxcMQe3nww
47b7d708b3127ccec26f6f7b9c7300000016100QcOWzNuxcMQe3nww
47b7d708b3127ccec26e1d26bc5b00000016100QcOWzNuxcMQe3nww
47b7d708b3127ccec26f1d249c1500000016100QcOWzNuxcMQe3nww
47b7d708b3127ccec26e05fcbc8d00000015110QcOWzNuxcMQe3nww
47b7d708b3127ccec26e5a2bfced00000016100QcOWzNuxcMQe3nww
47b7d708b3127ccec26e01d93d9a00000016100QcOWzNuxcMQe3nww
47b7d708b3127ccec26e5bd63db800000016100QcOWzNuxcMQe3nww
47b7d708b3127ccec26fac2cdcdd00000015130QcOWzNuxcMQe3nww
Eurosport ceramic coated race headers
ry%3D320
ball socket joint of race header and i added a flange for the first magnaflow ss resonator
ry%3D320
second magnaflow ss resonator and flanges again
ry%3D320
ry%3D320
end of second resonator with dual 90 degree mandrel bends leading over the axle.
ry%3D320
ry%3D320
Sebring stainless steel axleback muffler
ry%3D320
ry%3D320
dirty chromed oval tip
ry%3D320
ry%3D320
a pic from the rear
ry%3D320
Put a hi-flow CAT's in, the CAT's absorb a lot of the low frequency noise, the'll also be there during the MOT...
The car was registered Jan 92 so the cats not required and has passed its MOT with no problem on emmisions. The cat location would be the best bit to alter though, Sports cats are quite dear though. Will have to look in to it.
Oh right, sorry I didn't realise it didn't need one! An extra silencer then, although the packing won't last long up the front it'll still help.
