samthegram
Short shift for 2ltr 16v
i was wondering what short shift kits are available for the 2ltr 16v (cable change O2A) and are they worth having? Do they make much difference in reality?
Any thoughts would be appreciated.
short shifts will generally make the cable change much more notchy, you can buy complete short shift gear lever units(at huge expense) , or cut and re-weld the pivot plate of a standard VW one, I found the standard passat one will make about 25% reduction in throw, but you do need to cut and re-weld the bottom ball joint as it's a bit too low for the corrado system, 10 minutes of welding though, as long as you make a carefully measured template I'm sure you could find someone to knock that up for you for a beer. I'm thinking of making a few up this spring actually, I know a few others that have done it successfully too.
