jamin 0 Posted February 10, 2009 I'm in the process of trying to refurb these hubs, but cant work out how the damn ABS sensor comes off the housings (I've removed the obvious bolt, but it still wont budge!) - any ideas? DSCN1378.JPG[/attachment:1c96fj5f] Quote Share this post Link to post Share on other sites
joebloggsVR69 0 Posted February 11, 2009 There's only be one bolt keeping it on the hub - the one you've already removed It's probably just siezed on, try using some penetrating fluid and try knocking it out with a hammer Quote Share this post Link to post Share on other sites
iceviolet 0 Posted February 11, 2009 IIRC I used a socket to go over the sensor to protect and then tapped it out with a hammer. Quote Share this post Link to post Share on other sites
AlgarveVR6 0 Posted February 11, 2009 destroyed mine a few weeks ago getting it out. Blink codes had told me it was fooked so no issues really Put some copper slick round it when you put it back in. Dic Quote Share this post Link to post Share on other sites
jamin 0 Posted February 11, 2009 Thanks chaps, will give that a try. Does anyone know how much they are to replace, roughly? Quote Share this post Link to post Share on other sites
joebloggsVR69 0 Posted February 11, 2009 The front ABS sensor is about £55 from the $tealers I think Euro car parts sell them for about £10 less, though I'm not sure if they are the same part or an after market type Quote Share this post Link to post Share on other sites
fla 9 Posted February 11, 2009 I think GSF have them for about £15 each. They have a plastic housing so no rust weld. Having said that i still used some copper grease on mine :nuts: Quote Share this post Link to post Share on other sites
jamin 0 Posted February 11, 2009 Thanks again! Quote Share this post Link to post Share on other sites
aclwalker 3 Posted February 13, 2009 I've had to replace the same one twice on mine and both times I had to totally destroy the sensor to get it out. The first one was metal and was totally bonded on, but the second one was plastic and was stuck too. I think it had bitten very hard into the plastic. My second sensor got destroyed prematurely because the ABS ring was slightly warped just enough that the rust on the ring had swelled enough to lightly touch on the sensor, hence destroying it eventually. Try to 'enlarge' the hole slightly once you get it out by maybe lightly filing it or giving a touch of a Dremel. Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted February 14, 2009 The key is to use a wide ish screw driver and a hammer to get between the hub and the plastic, then just user the hammer to knock it out. Quote Share this post Link to post Share on other sites
jamin 0 Posted February 14, 2009 Thanks chaps, I've also found they seem to 'weld' themselves to the housings. We managed to get one of them out without destroying it. I think I might just buy new ones from GSF as I am refurbing the rest of the pieces. Quote Share this post Link to post Share on other sites
KIPVW 0 Posted February 14, 2009 Get on ebay for sensors, bought 2 a month or so ago for £24 delivered and they worked fine. :grin: Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted February 14, 2009 if you are removing the bearing and hub you will find a socket will go over the abs sensor and tap out with no damage at all,but without the bearing removed its a new sensor time.... :( Quote Share this post Link to post Share on other sites
pete_griff 0 Posted February 14, 2009 i had the same problem with mine. those sensors are inexpensive to replace - check out www.vwspares.co.uk the original ones have metal sheaths (as mentioned above) and are swines to get out withot damaging them. for the sake of a few quid, you may as well just get hold of some new ones. they are known to play up as the car gets older, so you should have peace of mind afterwards. also, (again mentioned above), the new ones they send oyu should have plastic sheaths, meaning they "should" be much easier to remove in future if you need to... Quote Share this post Link to post Share on other sites
