Sonicriot13 0 Posted February 28, 2009 What's the best way of cleaning up an oily engine in situ? The engine in my golf is all oily from a blown cam cover gasket and I want to clean it all up before replacing said gasket and the spark plugs etc. Quote Share this post Link to post Share on other sites
RDH 0 Posted February 28, 2009 Meguires degreaser really good, spray it on and agitate with a brush then rinse off, best stuff I have used. You dilute it so it lasts a good while. Also good for wheel arches etc. If you want something easier to get hold of (you would probably have to get Meguires off online supplier) Autoglym engine degreaser is ok. HTH Rich Quote Share this post Link to post Share on other sites
shawshankkid 1 Posted February 28, 2009 Autoglym engine & machine cleaner is brilliant stuff, very easy to use. gets my vote all day. Quote Share this post Link to post Share on other sites
Sonicriot13 0 Posted February 28, 2009 Thanks for that guys. Will see if I can get hold of either of those two tomorrow morning. Just want to clean it all up before fitting the new plugs as I don't want them getting fouled or have crud getting into the cylinders. Quote Share this post Link to post Share on other sites
Leonard 0 Posted February 28, 2009 Are there any bits which you should really cover with plastic bags when rinsing it off? Quote Share this post Link to post Share on other sites
RDH 0 Posted February 28, 2009 Are there any bits which you should really cover with plastic bags when rinsing it off? I am always carefull when rinsing off any degreaser etc in engine bay- would advise caution if using a pressure washer, in my experience the most sensitive items tend to be alarm systems-always worth tie wrapping a bag around them, might be prudent to protect dizzy, and always give engine a good run afterwards to dry it off/check running ok. Rich. Quote Share this post Link to post Share on other sites
Sonicriot13 0 Posted February 28, 2009 Are there any bits which you should really cover with plastic bags when rinsing it off? I am always carefull when rinsing off any degreaser etc in engine bay- would advise caution if using a pressure washer, in my experience the most sensitive items tend to be alarm systems-always worth tie wrapping a bag around them, might be prudent to protect dizzy, and always give engine a good run afterwards to dry it off/check running ok. Rich. Yeah, one of the guys at work suggested a pressure washer but seems a bit risky to me.... Not sure I'd risk it on an 18 year old engine. Plus I've only just put a new starter motor on yesterday, I could do without anymore electrical things going t*ts up. :lol: Quote Share this post Link to post Share on other sites
Sonicriot13 0 Posted March 2, 2009 Went for the Autoglym in the end. Really good, well recommended! :D Quote Share this post Link to post Share on other sites
DanVW 0 Posted March 2, 2009 Before and after pics??? ;-) Quote Share this post Link to post Share on other sites
belfastfumanchu 0 Posted March 2, 2009 What about a careful blast with the pressure washer before using the oil cleaners. Quote Share this post Link to post Share on other sites
Sonicriot13 0 Posted March 2, 2009 Before and after pics??? ;-) Didn't take any I'm afraid. I can get some after pics though. If it wasn't poisonous I'd use it on the dishes. Way better than Fairy! :lol: Quote Share this post Link to post Share on other sites
coullstar 0 Posted March 6, 2009 This stuff is good at getting oil stains from others peoples drives as well :brickwall: Quote Share this post Link to post Share on other sites
