corrado_sunderland
uprated map sensor for g60
You need a Rallye ECU as it has a 1.5 Barr map sensor.
bet ya there like rocking horse shit to get hold off too are they? why they different anywa same engine wasnt so why make ecu better :shrug:
I had a Mk4 Golf Map sensor on mine at one point, cant remember what bar it was but i was running 1.5bar on the engine. Then dont forget the remap that will be needed to suit.
Yeah you can buy the bosch part and get in soldered but it's tricky and as said above you can also use the sensor from a MK4 TDI I think.
If you can find a Rallye ECU for under £200 I'd get it!
