blue95 0 Posted April 24, 2009 Just wondered what idle peeps get on startup and when the car is warm? Does the idle change once engine is up to temp? Mines seems to be idling around 1250-1300 rpm Cheers Quote Share this post Link to post Share on other sites
Rob_B 0 Posted April 24, 2009 mine idles at around 1000rpm. doesn't really change after warming up Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted April 24, 2009 Does the QPE use the DBW throttle? Or are you guys having to run cable throttles and no idle control? Quote Share this post Link to post Share on other sites
blue95 0 Posted April 24, 2009 pianowire said: Does the QPE use the DBW throttle? Or are you guys having to run cable throttles and no idle control? No DWB, runs using cable throttle. There is an idle adjustment screw but there is no adjustment, may need to mod it. However the throttle was used before on another 20vt setup and was runnning fine. :scratch: I have emailed Ben (QPE) and it seems I may have an air leak around the inlet, so need to check gaskets etc :( Quote Share this post Link to post Share on other sites
