guy7809 0 Posted May 4, 2009 Hi all In need of some help as my vr6 corrado will not start. I was told by AAGUY!!!!!!!!!!!! i will need to take it to VW who will change ignition switch and new keys The car turnes over but cuts straight out. i have changed all plugs/plug leads/even the coil pack (cost a fortune) but no luck Any takers please Quote Share this post Link to post Share on other sites
Toad 0 Posted May 4, 2009 It's the factory immobiliser. You've either got a defective key, transponder reader ring on your ignition barrel or fuse 15 is blown. Quote Share this post Link to post Share on other sites
guy7809 0 Posted May 4, 2009 how do i go about sorting these possible problems out mate and do you know if i have to pay a fortune to get it done or could i do it myself Quote Share this post Link to post Share on other sites
Supercharged 2 Posted May 4, 2009 Have a look at this thread for the 'WD40 fix' viewtopic.php?f=1&t=38969 Worth putting what year car you have when posting problems etc... Quote Share this post Link to post Share on other sites
jimmyvwjunkie 0 Posted May 4, 2009 probs just your immobilisor. 3 cables to cut and reconect the originals. :grin: Quote Share this post Link to post Share on other sites
Toad 0 Posted May 4, 2009 You need to get someone to check it on Vag Com. The sensor ring is £25ish, but the new key and reprogramming will be more. The fault code scanning will tell you which it is. Check all your fuses first though.... Quote Share this post Link to post Share on other sites
guy7809 0 Posted May 4, 2009 Guys Brilliant I just took it all apart and cleaned it up and now working fine I now need to sell GUTTED Quote Share this post Link to post Share on other sites
