brian g60 corrado 0 Posted January 1, 2004 hello guys have a set of wolfrace 17s but need to fit spigot rings to fit properly. does anyone know were to get some. ally ones would be best. tried a search but no luck.i also have spacers on fronts,so longer spigots will be required for fronts .tried demond tweeks but no web site found . any help would be great cheers. :) Quote Share this post Link to post Share on other sites
W3RKD 0 Posted January 1, 2004 hi brian, try south coast wheels down in southampton they will deftinatly be able to help you out on those .. i have brought them from them before and there pretty cheap too... hth Quote Share this post Link to post Share on other sites
Henny 0 Posted January 1, 2004 demon tweeks = http://WWW.Demon-tweeks.co.uk 8) Most alloy wheel suppliers will be able to get these for you and they're normally pretty cheap too! 8) *edit* Hi Darren, you beat me to it! :roll: Quote Share this post Link to post Share on other sites
dubster82 0 Posted January 2, 2004 i went into the shop i bought my OZ's from and the guy just geve me one cause they had em lying about. Quote Share this post Link to post Share on other sites
G60Jet 1 Posted January 2, 2004 what does the spigot ring do anyway? Quote Share this post Link to post Share on other sites
Henny 0 Posted January 2, 2004 what does the spigot ring do anyway? They sit between the wheel and the central locating part of the hub to ensure that the alloy wheels are fitted dead center on the hub. If you have aftermarket wheels, you may need them as the center hole may not be the same diameter as the original wheel... The wheel bolts will make sure that the wheel stays reasonably centered, but on a 130+mph car, you really want to make sure that they are DEAD center, hence the need for the rings... 8) Quote Share this post Link to post Share on other sites
Supercharged 2 Posted January 2, 2004 Its not just keeping them centered, the inportance of them is to keep the force of the car on the road actually on the hubs, without the rings all the force is going straight thru the wheel bolts! Quote Share this post Link to post Share on other sites
G60Jet 1 Posted January 2, 2004 i thought it must be something like that but i thought the hub rings where a standard size for a given stud patten Quote Share this post Link to post Share on other sites
dubster82 0 Posted January 3, 2004 if these arent fitted, is it possible for vibration to be felt throught wheels at higher speeds, ie, wheel "feels" likes it may be buckled, but you know it aint....? Quote Share this post Link to post Share on other sites
Henny 0 Posted January 3, 2004 if these arent fitted, is it possible for vibration to be felt throught wheels at higher speeds, ie, wheel "feels" likes it may be buckled, but you know it aint....? Yup, in exactly the same way that if you've got muck beind your brake disks, then the brakes can feel warped even when they're not... 8) Quote Share this post Link to post Share on other sites
Supercharged 2 Posted January 3, 2004 As Henny said, you will feel it!! - I got a set of wheels for my mk2 and the rings that came with them would not quite fit on the hubs so I had to drive the car 5 miles to my mates workshop to get them bevelled down to size, I reached 50mph and you could feel the vibration, not a good experience!! Quote Share this post Link to post Share on other sites
dubster82 0 Posted January 5, 2004 As Henny said, you will feel it!! - I got a set of wheels for my mk2 and the rings that came with them would not quite fit on the hubs so I had to drive the car 5 miles to my mates workshop to get them bevelled down to size, I reached 50mph and you could feel the vibration, not a good experience!!yeah, i reckon my cars missing some then.... 50 on the nose and it starts shaking... as soon as i get a chance, they're gettin done then... Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted January 5, 2004 ive got one missing off mine when i bought them,had them fitted at demon tweeks and they put the wheel with the missing ring on the back,they said they arnt needed as much on the back wheel as the front Quote Share this post Link to post Share on other sites
brian g60 corrado 0 Posted January 7, 2004 now have two sets in each wheel for now and much better. they are all plastic,but would like to fit solid ,ally or steel single items in future. the size i am after is 63 down to 57.1mm. if anyone can help out great.also can you get spacers with built in spigot rings. Quote Share this post Link to post Share on other sites
