Stone0311
16v Running issues - Help needed
Recently finished a 16v conversion into my Mk1 (I know its not a rado, but im desperate) it was running sweet, started straight off the key and idled lovely as it had always done in my rado.
Came to replace my fuel lines as one had split, finished that today and started it up...............
After 5-10mins of running lovely it just cut out, i went to restart it and it took a while but then started and now idles at around 3K!
Every time i start it now its a pig to start and then returns to idle mega high
Has anybody any ideas? have to sort this out as i have my MOT on Tues morning
what 16v is it kr or the 9a?
and which fuel line did you replace?
don't know the 9a as well, but on a KR that valve allows air to bypass the throttle body for 5 mins whilst the car warms up before an electrc bitemallic plate shuts the hole, if this is bust then it will idle at about 2k
simple way to check is to to take it off and bung it in the freezer for 15mins - you should be able to see through the hole, stick back on the car and start and within five mins the hole should be shut
Its a KR, i replaced both the delivery and return lines
My 9a idles at 2k, i was told it's the idle air control valve that's faulty
Where is the idle air control valve?
Right, all vacuum lines and connections replaced - no luck.
Tried blocking off the vacuum connection from the inlet manifold (the one that goes to the servo etc) - no luck.
Checked gaskets and connections within the inlet manifold assey - no luck
any more suggestions?
nb also now have a vacuum gauge connected and that shows idle when its at 2.5K?
auxhillary air valve is between the filter and the TB
ISV's can get stuck, try cleaning it with carb cleaner or similar, also make sure the micro switch on the TB is activating the ISV, it should buzz when working
ISV cleaned and progress made.
It now starts quite happily and idles at 1500 rpm before rising to 2000 rpm after about 10s.
If there is still a leak i am quickly running out of places to look :scratch:
there's so many variables in the kr 16v fueling that it's hard to suggest things without being under the bonnet :D
you've definitely got extra air getting in somewhere, did you do an idle reset and adjust your idle when you transferred the engine over?
beyond the above I'd be making guesses about your control pressure being too low, or you introduced an air pocket which is allowing the air plate to rise more than it should
No, as it all came from my rado i transferred it directly - it ran sweet before the move, and for 3 weeks after
Air pocket - could i have done that when replacing the fuel lines? it was fine before they were replaced.
yeh, maybe worth a try to reset, the procedure is in haynes, you have to disconnect the connector near the coil, black and red ones i think, do a search - as am only just getting back into valvers myself
i was interested to know which pipes you'd replaced for that reason, but the flow/ return recircs quickly so doubt would be an issue.
you've covered the bases by checking leaks and the connectors are all correct, to diagnose further you need to start checking pressures and individual components... gets pretty involved :?
Going to steal the ISV from my m8s valver tom eve so il see if that makes a difference.
Annoyingly took that connector out coz it was damaged :brickwall: cant remember where it went now, made the loom at xmas.
There is 2 red/blk to the coil, any ideas where the one with the connector on goes to?
dunno mate, only got an engine in the garage at the minute :D
found Idle Adjustment guide
• Run to normal operating temperature (all electrical inc fan off)
• Disconnect crankcase breather
• Disconnect red/ black wire spade connector at coil
• Adjust idle to 1000?50rpm
Any other suggestions folks?
Progress made to-date:
Have now tested all of the piping to the ISV and the ISV with no luck.
Pretty much run out of places to look for a leak, could this be an engine management issue?
idle air bleed screw on throttle body clean and OK?
leaks from gaskets? try spraying carb cleaner or something around all the inlet boots and manifold, are the rubber sections of the inlet split?
Thats the one on the side of the throttle body? if so its all clean and seems fine
No splits in the inlet section, and no leaks from around the inlet manifold/assey - tb is closed @ idle so would have thought the leak would have to be after the tb or on the ISV inlet?
did you have the manifold off with the engine swap? could the gaskets be suspect
what about the injector seals are they new? they get very hard with age and once disturbed may leak air
Have the inlet gaskets arnt that old and were ok when i had it apart, will have to check the injector seals.
Can somebody confirm my thoughts here:
TB obviously governs the inlet of air into the inlet system
Depending on air demand the pressure plate in the metering head regulates the fuel sent to the injectors
During warmup/idle the ISV delivers air into the system when tb is closed
ur correct except last bit
- on warm up additonal air is allowed via the auxhillary air valve, as previous page, gray thing between filter and TB
- TB lets air in via idle screw
- the ISV flattens out engine hunting
