blue95
20v turbo alternator wiring help
Forgot to connect the little blue wire :scratch: now my battery goes flat
For the 20v turbo alternator, does anybody know of which of the 2 pins on the multiplug (highlighted below) this is connected to? as I don't have the connector.
alt.jpg[/attachment:3p09pjgv]
Cheers
hi there am do in converstion now do i need to use the golf hubs or can a just keep the corrado 1s so a dont av to by new wheeels?? tap bk thanks
cheers fellas sorted now!
£2 for the plug and loom from the dealers...got to love Vagcat!
All fitted and battery charging nicely now
hey mate u got a part number for the connector? need to get myself one!
No probs mate....
Flat connector - 1J0973772
Wiring set - S000979225A
No probs mate....
Have you used the thermo switch mate?
cheers dude, what is this thermo switch you speak of? :D
If you had the 16v lump it was mounted via one of the rocker cover bolts to a little stubby sensor, located on the corner of the rocker cover near the alternator, had a single wire connector. Basically just turned on the fans (separate to the 3 pin switch in the rad) after ignition was turned off to help keep all the bits and bobs cool.
Basically I was looking to change mine for the g60 stubby sensor which requires the 'engine head' temp to be 90c or below.
oh i know what you mean now, where would it fit on the 20vt? come to think of it i cant even remember where it is on the g60
Use one of the cam cover bolts to hold the bracket, nearest to the original position I guess. According to vagcat its on the back of the head on the G60.
