james_c2 0 Posted June 22, 2009 since ive had this raddo ive had a pretty big problem of it blowing the fuel pump fuse. sometimes can go 500miles without blowing, sometimes 1mile had it go at plymfest and every time the car started it would blow straight away. changed fuse and 3 days later drove 140miles without blowing changed the relay, filter and pump looks new, before i changed the filter it was pulling 16a when running warmish, now seems to be pulling about 4a when its running car drives perfectly fine over last couple of days its been harder to start, but has been sitting for about a month while i was away also when sometimes when its cranking over the rev counter starts acting irratic untill it starts went to start it earlier and took a while, went to start then died, looked at the fuse and it had melted it. any ideas? could it be the warm up regulators fooked or fusebox and doesnt seem to be on the fuelpump side of things. any help would be great before i change fusebox or hand to garage as its driving me insane Quote Share this post Link to post Share on other sites
flusted 0 Posted June 23, 2009 the live for the lambda shares same feed as fuel pump, bet the lambda live has scuffed through and is earthing out Quote Share this post Link to post Share on other sites
mad-dog 10 Posted June 16, 2012 surely if it was earthing out it would just blow the fuse?? i have the same problem on mine and am trying to find out why will try the lambda sensor ( didnt know i had one as mines an 90 16v tho) Quote Share this post Link to post Share on other sites
James. 9 Posted June 17, 2012 X2 for a short. Quote Share this post Link to post Share on other sites
mad-dog 10 Posted June 17, 2012 may have been for james _c2 but not for me :( mine doesnt have the lambda sensor on it so itcant be but i think it may be the fuel pump relay as i have removed the fuse box(to try and get the melted fuse out) and had a cursory look at the relay and its showing signs of shorting so hopefully replacing this will cure my problem hope james has his sorted too :) Quote Share this post Link to post Share on other sites
mad-dog 10 Posted June 28, 2012 mine seems to have been the fuse box have replaced it and let the car run and so far all good :) Quote Share this post Link to post Share on other sites
