voo51
How to remove Electric window white rollers??
Iam in the process of removing my passenger window glass. I have taken the door card off and undone the two bolts in the middle. However, I cannot get the white runner roller things off the bottom of the glass. I have tryed pulling them, bu I am scared of braking the metal arm. I have trayed to see if I can slip them out either end , but they do not go far enough.
Any suggestions??
if im right with wat you have described, they just pop of will alittle force....get a screw driver or pile bar between the bottom of window metal strip and roller,abit of force and it pops off :)
Yep, Managed to pull the little suckers off. However, I did cut my hand and on removal of the window glass I smaked myself in the nose with the glass when I pulled it from the door!
if you dont cut yourself while working on a car you have done it wrong, thats what my old man told me.
Anyone know part number for these white rollers? the thread on Corrado Canada Club mentions "535 837 437"... is this correct? Cheers
