bad-vw-boy
1990 1.8 16v coilovers
will coilovers fit across the corrado range or do they fit certain years or models? i have seen some on pistonhead but unsure of the make just wanted to know if they fit as they came off a corrado not sure what model, trying to find out, any suggestions
VR6 coilovers are specific however, as they will have a stiffer spring rate on the front struts to compensate for the extra weight of the VR lump.
Sweet i picked up a set over the weekend , however the set i have on the rado are bilstien and i cannot seem to get the top mount off as no tool can reach the 22mm nut as well as the hex 7mm key as well ....is there a knack for getting these off...in the past the cup they sit is shallower but these are very deep???? :scratch:
