lee55233
l reg vr6 brake limiter valve
the brake limiter valve has died on my vr6 l reg,does anyone know of a replacement or does it have to come from a vr6? many thanks
The bias valve on the rear axle?
Euro Car Parts sell them made by ATE so good quality, £55ish. The old one will probably be seized to the bolts/bracket and may need to be cut off, so coat the bolt holes and face that bolts up to the bracket with grease when fitting the new one.
just been under my car - my bias valve seems to rattle somewhat against the rear beam, although i cant work out where its doing it and more importantly, how. It only happens when you accelerate hard. In fact tbh i dont know if the exhaust is rattling againt it or vice versa. All the welds on the exhaust hangers and CAT heatshield are fine, maybe the rubbers have stretched? Any other ideas? ARB seems fine too but the noise is from the rear axle area. I'm confused. Zak this is the same rattle we looked at before, just finally manage to isolate it... i think...
here are a few pics of teh valve - is the adjustment correct? It looks a bit manky, before i gave it a good wipe with an oily rag. Any ideas or suggestions? Also, should there be some spring or anything else between the two holes, one on the valve body the other on the arm?
