jumboVR6 0 Posted September 7, 2009 had a new wishbone fitted and camber is out in the negative..... how do i adjust??.. im pretty good with my hands, but dont wanna touch anything without being sure.... any help would be greatly appreciated. :shrug: Quote Share this post Link to post Share on other sites
millerman 0 Posted September 7, 2009 get it done by laser alignment its the best way Quote Share this post Link to post Share on other sites
davidwort 0 Posted September 7, 2009 had a new wishbone fitted and camber is out in the negative..... how do i adjust??.. im pretty good with my hands, but dont wanna touch anything without being sure.... any help would be greatly appreciated. :shrug: just to keep your tyre wear to the minimum until you can get proper aligment checks done I'd slacken the hub to suspension leg bolts and adjust until you get around 0.5-1 degree of negative camber, on a 15" wheel that's about 7mm off the vertical from top to bottom on the wheel rim. Quote Share this post Link to post Share on other sites
StuartFZR400 0 Posted September 8, 2009 Ditto get it done by laser alignment its the best way But if you're going for a quick fix until you see the Laser guys, do as Wort says. Im sure he means the bolts in this picture, labeled 'A' HERE. From the pic you can see one bolt, but there is a second lower down too. Slacken both off (with car in air) and you'll see there is movement - adjust accordingly - but its a minute job. Hence its so important to get Laser alignment. Quote Share this post Link to post Share on other sites
jumboVR6 0 Posted September 8, 2009 thanks a lot people... great help... just gonna do a quick job for my tyre, till i can get it on the laser... thanks again.. :notworthy: Quote Share this post Link to post Share on other sites
davidwort 0 Posted September 8, 2009 if you get the camber about right the car shouldn't pull one way or the other, but if the toe (in or out) isn't right you'll scrub both front tyres over time, so don't leave it too long before getting all properly checked. A lot of toe in will tend to give very good straight line stability and steering self centering not to mention wearing the inside edges of both tyres. Quote Share this post Link to post Share on other sites
