daves16v 1 Posted October 7, 2009 So you're using early VR6 Passat hubs right? No, standard Corrado VR6 hubs. Quote Share this post Link to post Share on other sites
carpoid 0 Posted October 7, 2009 Doh, sorry i meant say discs :cuckoo: Too much reading through this thread :gag: I'll try again, So you're using early VR6 Passat discs right? :) Quote Share this post Link to post Share on other sites
mikkijayne 0 Posted October 7, 2009 Which Etka says are 288mm, hence why I was asking if you were using the VR6 calipers. Will the G60 ones work with the larger disk? Quote Share this post Link to post Share on other sites
daves16v 1 Posted October 7, 2009 Just checked, they are 280mm, you need to look for earlier Passat disks. The G60 calipers use 280mm disks as standard and they are the same caliper as the VR. Quote Share this post Link to post Share on other sites
mikkijayne 0 Posted October 7, 2009 Really? Hmm I checked the 95 Passat VR6 and it said 288x25. Is there an earlier one than '95? Do you have a part number I can check? Just curious now ;) Quote Share this post Link to post Share on other sites
Toad 0 Posted October 7, 2009 Model PA, Year 1993, MG 6, SG 15, Illustration 88-30. Either b 357 615 301 A >>31-N-255 989 Or b 1H0 615 301 A 31-N-255 990>> Quote Share this post Link to post Share on other sites
mikkijayne 0 Posted October 7, 2009 Cool thanks. I didn't realise they put them in the Passat in 93. Thats an early one then I guess :) Quote Share this post Link to post Share on other sites
daves16v 1 Posted October 7, 2009 Model PA, Year 1993, MG 6, SG 15, Illustration 88-30. Either b 357 615 301 A >>31-N-255 989 Or b 1H0 615 301 A 31-N-255 990>> Yes that is correct, 357 615 301 A are the disks I have. Quote Share this post Link to post Share on other sites
daves16v 1 Posted October 10, 2009 My 5 stud conversion is complete, just need to get the wheel alignment done. I'll post up some pics and details when I get chance. Quote Share this post Link to post Share on other sites
