vw domo 0 Posted October 27, 2009 The corrado has been running lumpy when its hot lately so i decided to GFS to get a new coil and ignition modual and they presented me with one of these............ Untitled.jpg[/attachment:1fg6spvl] iv got a cylinder type coil but as its one of the face lift models and im wondering weather its ment to have a pack rather than a cylinder? tried to fit a new cylinder type coil and it wouldn't fire up :shrug: anyone on the know with this? Quote Share this post Link to post Share on other sites
odub 0 Posted October 27, 2009 I had exactly the same experience. The coil you need to ask for is the one for the kr engine. Good luck Quote Share this post Link to post Share on other sites
shaung60 0 Posted October 27, 2009 I've only ever seen the 2.0 16V with a cylinder coil that has an amplifier(?) attached to it. Never seen one of those cubes on a Corrado 9A. Quote Share this post Link to post Share on other sites
shaung60 0 Posted October 27, 2009 But I do believe I've seen one of those on a MK3 Golf 2.0 GTi. Quote Share this post Link to post Share on other sites
davidwort 0 Posted October 28, 2009 I think some numpty has shown you a coilpack from an ABF engine (mk3 golf/passat/ibiza 2.0 16v) it uses a totally different injection and ignition system to the 9A 2.0 16v Corrado. The coil you need has an ignition amplifier attached and isn't the same as a KR one AFAIK, I have a KR system and a 2L 9A coil sat on a shelf in my garage, the physical coil cylinder looks similar, but so do all VW coils, the part numbers are not the same though. You may be able to use a KR coil on a 9A but you'd still need the 9A ignition unit that's mounted on it. Quote Share this post Link to post Share on other sites
vw domo 0 Posted October 28, 2009 thanks for your reply's guys, i might pop in to vw in that case and get the correct part numbers as the aftermarket sellers always seem to get it wrong. when the guy showed me the coil pack i knew it wasn't right so i got him to have a look (as i had the c with me) and he gave me a coil which was slightly different to the one on there at the moment. surprise surprise it didn't work so i took it back. i was just interested in which models this was meant for as they are advertised everywhere for corrados. Quote Share this post Link to post Share on other sites
vw domo 0 Posted October 29, 2009 vw want well over £100 for the coil and ignition modual and wouldn't give me the part numbers :censored: if anyone has a coil and ignition modual in good working condition could you let me know please. iv made a wanted thread to appease the mods! http://the-corrado.net/.archive/forum/viewtopic.php?f=14&t=85691 Quote Share this post Link to post Share on other sites
vw domo 0 Posted January 15, 2011 thread resurrection. iv been looking to purchase a new coil and modual again but it seems that if you have a 9a engine the only way is VAG :sad: (very expensive) has anyone successfully fitted a coil with a different PN or changed the plug-in to incorporate one of the dry coils? pretty sure i tried fitting an aftermarket coil listed for the kr and it didnt work. im guessing none of these options are possible due to the different ECU's. Quote Share this post Link to post Share on other sites
vw domo 0 Posted May 19, 2011 Fitted a BOSCH kr coil in the end from GFS, worked a treat :) part number is 0 221 122 399 Quote Share this post Link to post Share on other sites
tentonhammer 10 Posted September 6, 2012 Been a while now since anyone added to this - I'm in exactly the same boat as you (were). I need to replace the ignition coil in my C 92 16V 2.0 (9A) and can't seem to find a replacement anywhere! VW don't supply them anymore and third party suppliers want to sell me the square type coil which I know is wrong. I noticed you managed to find a suitable replacement using a coil for the KR engine Part Number: 0 221 122 399 - How long did this work for in the end? Did you have to re-fit your existing 9A ignition module as well? Any help would be great Quote Share this post Link to post Share on other sites
vw domo 0 Posted September 13, 2012 Been a while now since anyone added to this - I'm in exactly the same boat as you (were). I need to replace the ignition coil in my C 92 16V 2.0 (9A) and can't seem to find a replacement anywhere! VW don't supply them anymore and third party suppliers want to sell me the square type coil which I know is wrong. I noticed you managed to find a suitable replacement using a coil for the KR engine Part Number: 0 221 122 399 - How long did this work for in the end? Did you have to re-fit your existing 9A ignition module as well? Any help would be great just connects strait up to the 9a ignition module the same as the 9a coil. still going strong as far as i know! not got the corrado any more :( Quote Share this post Link to post Share on other sites
rodmax 0 Posted September 13, 2012 I have a good amp pack if you need one. Rod Quote Share this post Link to post Share on other sites
paulneale 10 Posted February 20, 2014 would a dodgy wire to the ignition coil aka G1 plug at the back of the fuse box cause the car to sometimes stall instead of holding its revs when stationary? Quote Share this post Link to post Share on other sites
