Matt DDK 0 Posted November 13, 2009 Hi I'm going to change the radiator on my VR6 at the weekend. I've purchased a genuine rad at £179 inc the VAT. The parts dept recommended that I use 3 litres of G12. Is this enough and do you advise doing anything else other than flushing out whilst apart? Thanks Matt Quote Share this post Link to post Share on other sites
davidwort 0 Posted November 13, 2009 you need about 60/40 distilled water/coolant, so that's about right for a VR cooling system. Quote Share this post Link to post Share on other sites
fla 9 Posted November 13, 2009 as Davidwort has said, use some distilled water - carplan 51p per litre from Tescos! Also, flush the cooling system out rally thoughly - if you can, disconnect one hose for the heater matrix and stick a hosepipe in there until it runs nice and clean. Also, flush the block as much as possible from the top hose using warm water. Take the thermostat housing out, replace the stat and seals if you like (or clean the stat with vinegar), clean up any muck around there, flush teh pipes and reassemble. If you have time, take the water pump out and clean this with vinegar too. Then refit, use your new rad and enjoy your nice cool running VR! Quote Share this post Link to post Share on other sites
ryan_16v 0 Posted November 13, 2009 Why distilled.? Quote Share this post Link to post Share on other sites
fla 9 Posted November 13, 2009 basically because this stop the hard water salts (calcium carbonate and Calcium hydroxide) being deposited in your rad and cooling system. MEG in te coolant does also act as an inhibitor but using deionised means theres nothing there in the first place. Just like the crud that sits on your kettle heatig element. You dont want that in your system. Might need calgon otherwise :) Quote Share this post Link to post Share on other sites
ryan_16v 0 Posted November 13, 2009 I see.. :) Quote Share this post Link to post Share on other sites
Matt DDK 0 Posted November 14, 2009 Thanks Guys for the info, I hadn't thought about using distilled water but it def makes sense. You say to use a 60/40 mix but being new to Corrados how much water do they hold? Thanks Matt Quote Share this post Link to post Share on other sites
Supercharged 2 Posted November 16, 2009 An Auto VR holds 9.5 Litres so 2 x 1.5 Ltr bottles of G12++ with water should be fine. Quote Share this post Link to post Share on other sites
