mlyon89
Rough when cold issue!
what is the most common sensor to stop working or go dodgy to coz it to run like a bag of s*** when cold people?!?
The car starts no bother but i've gotta keep my foot on the throttle for a we while till she warms up!
am i right in saying its the blue sensor and if so where about is it?!? I did have a cd-rom manual but i've lost the bloody thing!!
Cheers for any replies!!
The blue temp sesnor is in the plastic thermostat housing at the front right hand corner of the block, just below the inlet manifold. It sounds like likely candidate for the problem, basically reading a higher temp than it should.
yes isv stands for idle stabilisation valve, suspect coolant temp sensor open circuit, or out of perameters, check with a multimeter on ohms if open the display will read blank no reading :D
