-=Kris=-
"ABS is on absolute f*ckaries!"
OK, so my ABS has not been working for a while now, and decided to take it to my mechanic to finally get it sorted...
he has looked at the car a while ago during the yeah and said that the rear sensor rings where not even there!
i knew there was an issue with the ABS for a while so i managed to find a cheap ECU and Pump on the forum just in case these had issues... i put these in the boot just in case he needed them...
got a call yesterday with a message left...
"Kris, your ABS is on absolute f*ckaries! give me a call back"
So i call him back, find out that the ABS wiring loom is buggered on the drivers side and VAG computer is showing an ECU fault... ECU replaced, now Pump is showing a fault...
luckily i had both the ECU and the pump... phew...
so i said go ahead and replace the loom and that should be the end of it...
replaced the pump and loom and calls back... "your front passenger side sensor is showing a fault now..."
argh! he said it wasn't showing it before he replaced the pump so there could be a problem with the 2nd hand pump i baught...
but we won't know till i replace one part or another... so i've told him to replace the sinsor... thats another £100 on the bill...
hopefully it's all working after that!
well i just needed to vent...
i should get a call from the doc later today... wish me luck!
That's a bit of a sh*tter...you should be like me, my abs doesn't work and I choose to ignore it. Its a much simpler, stress free solution. :D
I was doing that for the 2 and 1/2 years i had the car till i locked up and almost went into the back of a corsa the other day...
that pukkered up my ahole!
so i decided to send it to Jason...
actually... i'd recomend him to you mate... he's in croydon... Mayday Auto Center just off Addiscombe Road...
actually... i'd recomend him to you mate... he's in croydon... Mayday Auto Center just off Addiscombe Road...[/quote:z0nydrqg]
I know the one mate, I work on the next road along! That's a bit of a freaky coincidence considering you live in Fleet. :shock:
actually... i'd recomend him to you mate... he's in croydon... Mayday Auto Center just off Addiscombe Road...[/quote:ajs231mw]
I know the one mate, I work on the next road along! That's a bit of a freaky coincidence considering you live in Fleet. :shock:[/quote:ajs231mw]
Yeah, i've always sent my cars to him... the guy is a legend!
if you go past you might see my motor sitting in the car park or the road...
i heard back form him just now... it's all up and running! :clap: :clap: :clap:
I used to live in Kingswood, which isn't too far from there to get a decent mechanic... but i don't trust anyone else... i will always take it to him...
