marmite monster
Double din climate control nav ??? how tf?
the double din is apparently very easy, just need to find one and then hack the dash a bit to make it fit.
the climate control im not too sure about but that car has got a 2.8 24v engine in so it will be from a mk4 i would assume
That is soooooooo nice!!!
I have just fitted a double din headunit, it has been a right hassel with the temp panel. But, that climatic mod looks loads better. You have to make some sort of frame inside the dashboard to support the double din unit. Mort as fitted that sat nav on the forum. He might know bout the climatic mod?!
that look absolute quality!!
I'd also be willing to pay someone to make that happen for me!
Do we not have anyone here on the forum that can simply say, "bring your corrado to my house/garage, and I'll do it for you for £XXX" ?? :shrug:
