chris001 0 Posted December 5, 2009 Dont want to sound to dumb but, whats the differance between an ODB 1 and ODB 2 engine pls ? :confused4: Also are any of the parts interchangable like the rocker cover, manifolds etc ? Any info greatly appriciated ! :) Quote Share this post Link to post Share on other sites
Toad 0 Posted December 5, 2009 OBD1 and 2 refer to the engine management. OBD 2 is more advanced, and has better control over the engine. It uses a stepper motor on the throttle body to control the idle rather than a ISV. Otherwise it's quite similar to a late OBD1 VR6. To convert a car you need the inlet manifold, throttle body, MAF, coilpack (if you have a distributor based engine) wiring loom, and ECU. There are a few threads on the subject of converting a car if you have search. Quote Share this post Link to post Share on other sites
chris001 0 Posted December 5, 2009 Thanks for that, not wanting to convert my car just wanted to know if i bought say a rocker cover for a OBD 2 would it fit a OBD 1 ? My c is a 1994 VR6 so guess its OBD1 ? Thanks :) Quote Share this post Link to post Share on other sites
Toad 0 Posted December 5, 2009 All corrados are OBD1 unless they have been converted afterward. The rocker cover has nothing to do with the engine management type, but they do change, from a metal unit to a plastic one. The metal cover fits over studs in the head, the plastic one has bolts in it to clamp it down. Quote Share this post Link to post Share on other sites
chris001 0 Posted December 5, 2009 Cool ! Cheers for clearing that up for me ! :clap: Quote Share this post Link to post Share on other sites
