Jon_vr6
Dual pole sender
Iam sure its the M10 !
when i ordered mine ,i rang up and spoke to them,they do know their stuff,and they pointed me in the right direction.
If you dont find out ,i will go a rummaging through my reciepts
Your lucky day, found the reciept
vdo oil pressure 10 bar sender m10 x 1 w/c o.5
stock code 360081030009 with vat and postage mine was a whopping £69.79 !!
Just got an email back from merlin and they said that the one i need is out of stock they are waiting for VDO germany to recieve their stock so they can then supply merlin with the part will get in touch with them in the new year
Sender is £57.49
Sender is £57.49
Apparently you can order these from VAG - T11 919 081 for £23, its a "proctected" part so my dealer says - so they are having to order it through TPS. I’m not a hundred percent sure if this the right item, but I’ve ordered one non the less as i ran into the same problem as you with back ordering with Merlin. Lets hope its correct so i can get the gauges fitted over Christmas :clap:
