marmite monster
HI SPEC brakes? any good?
To my mind if you have to ask the question then I would choose something else.
Have you ever seen them being used on anything in competition? I haven't. Might be OK, but for the money there are better option IMHO.
Jay
Ive got a set of 285mm and four pots on mine !
I rate them,they fit behind my 15" estoril,no spacers, even the skinny spare fits !!
and yes they do stop incredibly well,the calipers will go upto a 350mm disc !so if you ever need more braking,just buy new discs and pads,ive used hi-spec parts many times through the years,i always go to their shop (30 mins away)
very friendly,and very very helpful.
Well a friend of mine runs em on his 280 hp polo and tbh they stop it from 160 to dead without much probs... he swears by em!
If i had read the comments posted in the link by Yalan, i wouldnt have bought Hi-Spec !
But i did buy a set,about 12k ago,and i have nothing but praise for them,
After sales service was top notch,maybe cause i go to their workshop and deal direct,cause ive used them before i get a 10% discount,
285mm brakes + 4 pot calipers= modern day braking and then some
I keep toying with the idea of using their rear 4 pot calipers !
now where did i put that lottery ticket !
Have they got an integral handbrake mechanism?
I've been looking for something decent to replace the standard rear calipers with for ages, but nothing has yet presented itself. I don't want to run a seperate handbrake caliper. It's not for increased performace, but for reliability and smoother operation. The standard rears as we all know, are complete t0ss this time of year.
My mistake,2 pot rear calipers,w
SVA Rear VW Lug Caliper
The SVA VW Lug Caliper is based on our popular 2 piston Ultralite caliper. This caliper will bolt directly onto any car using the VW Golf hub and is lightweight and compact. The design of the caliper will allow for fitment onto discs from 6mm to 35mm. Suitable for vehicles up to 1500kg. Handbrake cables are available in three lengths to be used with our SVA calipers.
Patent pending
Features
Lightweight and compact
CNC Machined Aluminium Body
Moving components manufactured from Stainless Steel
Rigid Design
Easy to Fit
Incorporating separate handbrake pads
Available to match front conversions.
Technical Specification
Disc Thickness 6mm - 35mm
Piston Size 2 x 38.6mm
Piston Material Hard Anodised Aluminium
Pad Size
Weight
Hydraulic Thread M10x1.0
Standard Calipers
(Black, Blue, Gold, Red, Silver)
Part Number Caliper Piston Disc Size Price (£) + VAT
CAL-SVAVW-260-06D SVA Spot VW 260 Lug 38.6mm 06mm 140.00
CAL-SVAVW-260-10D SVA Spot VW 260 Lug 38.6mm 10mm 140.00
CAL-SVAVW-260-12D SVA Spot VW 260 Lug 38.6mm 12mm 140.00
CAL-SVAVW-260-20D SVA Spot VW 260 Lug 38.6mm 20mm 140.00
CAL-SVAVW-260-24D SVA Spot VW 260 Lug 38.6mm 24mm 140.00
CAL-SVAVW-260-26D SVA Spot VW 260 Lug 38.6mm 26mm 140.00
ith built in hand brake,
They certainly look like nice kits and they won't break the bank either.. you can get the full 285mm kit for a Corrado for a little over £600. Not bad at all. The 300mm kits still come in at under £1000!
