C488ADO 0 Posted January 3, 2010 ok as my other thread was locked im not sure where this is supposed to go... as i couldnt get my vag com working i thought it time to go back to basics and use what little mechanical knowledge i have ... the car starts the car does not idle the car does run if i use the throttle to keep it running.... the car dies at junctions so i located the isv,?? i have had problems in the past with damper boxes and the morning the problem started i heard a loud back fire bang type noise, (something to do with pre-ignition within the damper box) (fumes etc ) ??? what causes this i dont know but it does happen now and again.... anyway located isv and stripped it out it was full of the wadding from the damper box hence no idle! so cleaned it all out re fitted and hey presto runs like a good un! like i said this was the prob that was the solution not sure where it can go to maybe help someone else feel free to move as im sure you will! cheers Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted January 3, 2010 Glad you sorted it- the exact same thing happened to me with my last VR. Quote Share this post Link to post Share on other sites
