daves16v
A Guide - 4 to 5 Stud Conversion
I went 4 to 5stud but stayed narrow track (due to having everything poly bushed and refurbed) and got 288 disc. only thing that was a slight prob was to machine down caliber carriers. do you want a list of what i used?
right, this was mainly thanks to mikkijaneShe gave me the idea/knowledge how to keep narrow but go 5 stud. (i think thats her user name, the one thats building the v8 c)
I used,
mk 3 golf 288 caliper and carrier (carrier i had machined down to allow for correct offset- think it was 5mm)
288 pads
mk3/vr cv joint
16v hub carrier
16v cv/hub bearing
16v wishbones and subframe
288 disc (think, will double check when back at work these where for a bora)
think that was it.
hi mate.is this the same set up i will need for a g60?not sure the difference between the 16v and g60 set up.cheers.
