chris001
Mk4 Golf Rear Callipers
Hi, my rear callipers are pretty much knackered and have heard of people fitting Mk4 rear callipers.
Was wondering excatly what do I need to carry out the conversion, where's best to get the parts from and roughly how much would it cost ?
Any advice much appriciated ! :)
Basically you need the 2 calipers and a pair of MK2-MK4 conversion hoses from Goodridge...
http://www.vwspares.co.uk/product_info. ... ts_id=1530
http://www.vwspares.co.uk/product_info. ... ts_id=1531
The above should cost about £130 + the Hoses are £25 so you can do it with brand new bits for around £150 and no exchange required on the calipers!
If old I would consider also doing new rear discs, Pads, wheel bearings, ABS rings, splash shields and handbrake cables - another £150 or so.
That was quick ! :)
Do I need new carriers as well ?
What about disc's and pads ? Do I need Mk4 items or do I use Corrado ones ?
Cheers
No, everything else Corrado including the carriers.
A few of us have changed carriers now due to corrosion and pads seizing up but they usually clean up fairly well...
Tidy ! My carriers are quite badly corroded so would need to change them. I spose my best bet would be to keep an eye out in the for sale section fo a set or can you still get them new ?
cheers
Me again ! :) Going slighty of subject but, got the same question but about for the front. What do I need to convert the front to 288 disc's ? :confused4:
i made two good threads about both of these questions, and they both have all the part numbers and photos of each bit :D
just need to find them
Thanks loads for all your help guys, especially those links they will be very useful !
Just have to get the parts and get busy ! :clap:
