olly elworthy 0 Posted January 23, 2004 will this work? Quote Share this post Link to post Share on other sites
Sandy 0 Posted January 23, 2004 don't think so koni list different kits for each model Sandy G60 (might be wrong) Quote Share this post Link to post Share on other sites
Bally 0 Posted January 23, 2004 This may help.. http://the-corrado.net/.archive/forum/viewtopic.php?t=6470 Quote Share this post Link to post Share on other sites
andycowuk 0 Posted January 23, 2004 the pre-load in the front ones will be set higher.....cos the vr6 is fatter....if you are sending them away to be reconditioned.....you can ask to have preload reset differently at no extra cost I think (they have to reset it in a recon anyway) Quote Share this post Link to post Share on other sites
cramer 0 Posted January 23, 2004 You can use VR6 coilovers on a G60. I am running H&R VR6's on mine. All you need to do is use the VR6 upper front strut bearing. Everything else is the same between the two cars. Quote Share this post Link to post Share on other sites
