vagman 0 Posted March 3, 2010 The time has come to overhaul my cooling system, car is still running a little hot and i have a small pool of water directly below the thermostat housing area every now and again! Please i am going to undertake this job myself and would be grateful for all the advice i can get, i have dabbled a little with cars and i dont mind having a go. I have had a look for the thermostat housing parts list and cant seem to find it, i am going to order a new OE radiator just so i know its covered, i have also just got a new OE 3 stage rad switch along with some G12+ coolant! I want to get it done before the end of march before the hot weather comes. What sort of money should i budget for all parts, all tips and advive very welcome. Quote Share this post Link to post Share on other sites
jaded2882 0 Posted March 3, 2010 I had a similar leaking problem on mine. I just changed the two flanges on the engine (make sure you get the O rings too). For them, the thermostats and a load of G12 can't be much more than about £40? Easy job too, just make sure your ready for the torrents of coolant! Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted March 3, 2010 loads of info on this mate http://the-corrado.net/.archive/forum/viewtopic.php?f=1&t=55166&hilit=thermostat+housing Quote Share this post Link to post Share on other sites
vagman 0 Posted March 3, 2010 loads of info on this mate http://the-corrado.net/.archive/forum/viewtopic.php?f=1&t=55166&hilit=thermostat+housing Ahh, thats what i was looking for thanks! Quote Share this post Link to post Share on other sites
jaded2882 0 Posted March 3, 2010 oops, very different on a vr6 :roll: sorry! Quote Share this post Link to post Share on other sites
vagman 0 Posted March 9, 2010 Hi people, i have a couple of questions please! First.... does the new 3 stage rad switch just plug/screw into the new rad, or do i need a O'ring or a bit of PTFE tape??? Also i have read the cooling guide, but i am still unsure to what is best/ use a bit of silicone when rebuilding stat housing or just put together with just the rubber seals alone??? Any advice would be appreciated, thanks Quote Share this post Link to post Share on other sites
vagman 0 Posted March 10, 2010 ....................Anyone??? :? Quote Share this post Link to post Share on other sites
Goldie 2 Posted March 10, 2010 When i did mine i just used the seal. While you are in there you might as well change the housing, stat, all seals.. Another piece of advice i was goven was dont go mad with the G12, it doesnt need to be too pure as the cooling properties of the G12 are different to water. I was advised it would lead to a 10% difference and hey presto when i drained and refilled to a less concentrated mix it was spot on. Quote Share this post Link to post Share on other sites
Chris 0 Posted March 10, 2010 Hi people, i have a couple of questions please! First.... does the new 3 stage rad switch just plug/screw into the new rad, or do i need a O'ring or a bit of PTFE tape??? Also i have read the cooling guide, but i am still unsure to what is best/ use a bit of silicone when rebuilding stat housing or just put together with just the rubber seals alone??? Any advice would be appreciated, thanks just use a bit of jet blue sealing compound around the rad switch (all plumbers should have some :D ) tbh ptfe tape will work too but i always use jet blue as i prefer paste rather than tape in plastic. you shouldnt have to use silicone or gasket seal. if all the components and seals are new/good and the job is done properly it wont leak. Quote Share this post Link to post Share on other sites
vagman 0 Posted March 11, 2010 When i did mine i just used the seal. While you are in there you might as well change the housing, stat, all seals.. Another piece of advice i was goven was dont go mad with the G12, it doesnt need to be too pure as the cooling properties of the G12 are different to water. I was advised it would lead to a 10% difference and hey presto when i drained and refilled to a less concentrated mix it was spot on. Cheers for that, ordered job-lot for cooling system also new senders and switch's and neuspeed stat! That should do it! Quote Share this post Link to post Share on other sites
